  1. I need best program and short introduction thanks.
    :oops:
  2. use the one they suggest here and follow the guide
    hope the answer isnt to overwhelming for such a detailed question that you obviously researched completely before you posted here.
    peace out,
    dumwaldo
    AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
  3. Use VCD gear i had the same question and I got laffed at it will workand it is very fast
